Verdeck Problem
Zitat:I also found a couple of white wires with transparent and red ending
disconnected in the left side of the trunk. I looked around to find the
connectors in which they were supposed to be in, but I saw nothing. Do you
know anything about them? Here is a picture of them:
Don't worry! These cables are normally used for the automatic antenna. If
you don't got one, it's O.K. to leave them unconnected. Zwinker
Hi.
The antenna is automatic, but it only has a wire with a small transparent switch.Dry
Anyway it is good to know that they are not part of the verdeck "team" Rolleyes
If I remember it right the unconnected ones on your pic are for the built-in
amplifier of the !original" automatic antenna.
Hola otra vez Smile
avogadro schrieb:3. I checked for the wires in the trunk (only visually, checking the black cable around the trunk), both right and left ones. I saw where they ended and check for the switches (right and left sides), no wire out of its place. I supposse that I will have to change both wires for new ones. I imagine that even if the black cover of the wires is not broken, they could be broken inside, no??? At first sight it seems to be impossible that the wires might be broken inside, but of course they can be.
Visual checking is absolutely not enough.
Please remember Bastel1977's hint from above:
At least you should check the cable with your hands, mainly at that point where the cable bends most. There you should feel the broken wires...
But even if you don't, I encourage you to repair the cables on both sides anyway!
Your cables are aged enough that it is almost certain they're broken, so don't hesitate Cool
Remember also:
Ollfried schrieb:These steps solve about 97.452% of all roof-problems.
Big Grin
BUT: Don't go to your friendly Audi dealer, there you'll only get the same non-satisfying quality again. Even worse: You'll have to pay a whole bunch of Euros...
Instead, i would recommend you to order them here:
Firma FOBO OHG
They are of much higher quality and less expensive than the original cables and best of all: plug'n'play Smile
If you need help to do so, just send me a PM... Zwinker
Zitat:Saludos para todos/as desde la playa (hoy mucho viento y nubes) y hasta mañana.Smile
Saludos desde la playa del mar báltico (hoy sol ahora Smile ).
Hasta próxima!
HZwinkerlli
[Bild: 118275_5.png]
That is the next I will do, to change the verdeck's wires in the trunk. Let's see if the problem can be solved very soon. Ganz geschmeidisch...
Thanks Zwinker
So Leute,
damit hätten wir den ersten Spanier auf unserer UserMap Smile
Herzlich Willkommen im Board, Avogadro (dies ist ein Deutschtest Big Grin ), und ich hoffe, Du wirst uns demnächst berichten, dass Dein Verdeck wieder funktioniert Rolleyes
Anderenfalls hoffe ich für Dich (sowieso), dass Du eine Klimaanlage in Deinem Cabrio hast... Cool
HSmilelli
Holli, das schreit nach der ersten TDE 08!
Ich wär dabei!
H;o)lli schrieb:So Leute,
HSmilelli
Vielen Dank für die Wilkommen. Smile
Und ja, Ich habe Klima in meinem Cabrio, and funktioniert!!!Cool
Mit dem Forum hilfe das Verdeck wieder funktionert, sicher.
Danke. Bis bald.
ooowe78 schrieb:Holli, das schreit nach der ersten TDE 08!
Ich wär dabei!
Höhö.... bei 5,2L/100Km/h würde ich auch "hier" schreien.... Bääääää
Aber da müssen wir Avogadro fragen, ob er eine Tour De España 2008 für uns plant... Zwinker
Wenn unsere Hilfe erfolgreich sein sollte, dann müssen wir Herrn Forster möglicherweise noch 'ne Einladung schicken.... hehe
Gruss, HJawoll Chef!lli
!Hola avogadro!
Bienvenido al nuestro foro de las coches mas guapas.
!Mi casa es Su casa, companero!
en aleman...
TDE! Goil! Jawoll, da wäre ich auch dabei!
Offensichtlich ist ja schon alles zum Thema Verdeck gesagt... daher kann ich leider nichts weiteres zum eigentlichen Thema beitragen...
Aber TDE... das lässt mich nicht los. Sangria statt Komodenlack... wäre wohl ne Alternative...(Komodenlack = Ich sach nur TWT 07...)
Lorenz, Aquisgran, Alemania
  Problem Verdeck Jacky K 1 1.413 12.05.2025, 20:37
  Verdeck Seil Problem beim Aufklappen?? M4st3r M M 5 8.625 04.04.2025, 15:20
Letzter Beitrag: rofacabrio
Lightbulb [Problem] E-Verdeck Problem - Auswertung Messwertblöcke Sparxx12 31 24.792 06.06.2023, 09:43
Letzter Beitrag: Sparxx12
  Problem mit dem Verdeck Pete5 3 5.432 18.05.2023, 10:31
Letzter Beitrag: Scotty
  Problem Microschalter Verdeck Fritz2014 36 27.379 05.07.2021, 18:18
Letzter Beitrag: aucabdriver
  [Elektrisch] E-Verdeck Problem (Verdeckdeckel) Webster 7 11.431 15.04.2018, 17:30
Letzter Beitrag: Webster
  Problem mit dem Stromlaufplan vom Verdeck Doffl 0 3.286 21.03.2015, 18:04
Letzter Beitrag: Doffl
  Riesiges Problem mit Verdeck Audicabriolpg 8 10.257 27.01.2014, 09:17
Letzter Beitrag: Ralph
  Verdeckkasten Problem Manuelles Verdeck Serkan.S 4 7.908 25.11.2013, 23:31
Letzter Beitrag: Serkan.S
  Man. Verdeck problem sinox87 103 120.372 30.09.2013, 12:00
Letzter Beitrag: streaky
