Verdeck Problem
Hola Avo Big Grin
avogadro schrieb:The point is that in the last two weeks it has been working by days, sometimes yes , sometimes no.
This is an almost certain indication for broken wires mainly in the cable to the right of the trunk.
Anyway, You should swap both of them, left & right, because they're of same age and sooner or later the other one will get you into trouble too...
If you need further help to get the right wires/cable that will definitely be better than the original ones, let us know.
Saludos y hasta próxima,
HZwinkerlli
[Bild: 118275_5.png]
Verdeck Problem - von avogadro - 10.02.2008, 22:47
RE: Verdeck Problem - von Mech© - 10.02.2008, 23:07
RE: Verdeck Problem - von kawa116 - 10.02.2008, 23:09
RE: Verdeck Problem - von Bastel - 10.02.2008, 23:13
RE: Verdeck Problem - von Ollfried - 10.02.2008, 23:35
RE: Verdeck Problem - von Maveric - 10.02.2008, 23:39
RE: Verdeck Problem - von Ollfried - 10.02.2008, 23:47
RE: Verdeck Problem - von avogadro - 10.02.2008, 23:47
RE: Verdeck Problem - von H;o)lli - 11.02.2008, 00:11
RE: Verdeck Problem - von avogadro - 11.02.2008, 21:20
RE: Verdeck Problem - von H;o)lli - 11.02.2008, 21:44
RE: Verdeck Problem - von Mech© - 11.02.2008, 21:27
RE: Verdeck Problem - von avogadro - 11.02.2008, 21:31
RE: Verdeck Problem - von Mech© - 11.02.2008, 21:36
RE: Verdeck Problem - von avogadro - 11.02.2008, 22:42
RE: Verdeck Problem - von H;o)lli - 12.02.2008, 00:29
RE: Verdeck Problem - von avogadro - 12.02.2008, 00:59
RE: Verdeck Problem - von Owe - 12.02.2008, 00:53
RE: Verdeck Problem - von H;o)lli - 12.02.2008, 01:03
RE: Verdeck Problem - von Grappa - 12.02.2008, 01:53
RE: Verdeck Problem - von Owe - 12.02.2008, 02:07
RE: Verdeck Problem - von avogadro - 14.02.2008, 22:27
RE: Verdeck Problem - von H;o)lli - 14.02.2008, 23:20
RE: Verdeck Problem - von avogadro - 14.02.2008, 23:57
  Problem Verdeck Jacky K 1 1.410 12.05.2025, 20:37
  Verdeck Seil Problem beim Aufklappen?? M4st3r M M 5 8.625 04.04.2025, 15:20
Letzter Beitrag: rofacabrio
Lightbulb [Problem] E-Verdeck Problem - Auswertung Messwertblöcke Sparxx12 31 24.766 06.06.2023, 09:43
Letzter Beitrag: Sparxx12
  Problem mit dem Verdeck Pete5 3 5.429 18.05.2023, 10:31
Letzter Beitrag: Scotty
  Problem Microschalter Verdeck Fritz2014 36 27.321 05.07.2021, 18:18
Letzter Beitrag: aucabdriver
  [Elektrisch] E-Verdeck Problem (Verdeckdeckel) Webster 7 11.417 15.04.2018, 17:30
Letzter Beitrag: Webster
  Problem mit dem Stromlaufplan vom Verdeck Doffl 0 3.283 21.03.2015, 18:04
Letzter Beitrag: Doffl
  Riesiges Problem mit Verdeck Audicabriolpg 8 10.254 27.01.2014, 09:17
Letzter Beitrag: Ralph
  Verdeckkasten Problem Manuelles Verdeck Serkan.S 4 7.902 25.11.2013, 23:31
Letzter Beitrag: Serkan.S
  Man. Verdeck problem sinox87 103 120.305 30.09.2013, 12:00
Letzter Beitrag: streaky
