29.06.2004, 13:13
Rasmus,
usually it is the voltage regulator causing trouble with the fuel and temp gauges. You might want to consider to re-replace it.
In addition, you should check the proper torque of the nuts holding the gauges and the voltage regulator. If they don't have proper contact, the gauges do whatever they want.
Lord
Cab2,3
hier eine Explosionszeichnung des Startventils mit Einbauort. Nr 3 ist das Ventil
Lord
Lord
Cab2,3
Lord
Zwo-Achter mit Allem
, Recaro Sitze
![Bin verärgert! Bin verärgert!](https://www.audi-cabrio-club.info/forum/images/smilies/angry.gif)
