Probleme E-Verdeck mit VIDEO!
(19.02.2009, 22:00)lemmy schrieb:
Tux schrieb:You even had to WHAT ? Dismantle the tank ?
Take a pill and calm down, Thilo, Dumdididum
I guess he means the oiltank on the hydraulic pump... Is dat wirklich so?
@Lars: Please feel free to post in English. Somebody should be able to translate... Nenene
Zwinker
Thanks Zwinker Yes I ment the Hydraulic pump. I saw the word in another string and thought it could fit in the text Zwinker But i DID remove the tank.
(19.02.2009, 22:18)Grappa schrieb: One comment regards your empty battery. Do not attempt to start the car with an empty battery! Since you have got the V6 2.6 (ABC), you would certainly risk to put the engine control unit (ECU) into backup mode. Once entered, the ECU loses information on the correct throttle position and the idle stabiliser characteristics. Unfortunately this is no self-learning system, thus a reset via OBD (at a repair shop or via certain hard and software) is mandatory to get the ECU back into calibrated mode.
Thus, my recommendation would be: First recharge the battery. Then switch on ignition, but do not start. Check the battery gauge. It should read 12V+x to ensure a save start of the ECU.
Oooops I did and when I did it the dash panel died and the engine just clicked. But when I removed the key and inserted it again and put ignition on the lamps lit again but I didn't try to start the car. I hope certainly hope it will be OK Da bin ich aber traurig!
Zitat:Good luck.
I would be happy to read your response (telling that you had success).
Me too Smile
Zitat:Keep posting in "any" language... I guess - to a certain extend - this community is international enough to handle that Smile
But I am trying to be polite Rolleyes
In school I learned german for three years but that was thirty years ago and you know if your not keeping it up you forget. Am I doing well with the german? I speak better than I write.
I know there are many funny grammar faults that I do continously but it's on me, for free. Big Grin
Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 13:45
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 14:46
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 15:31
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 16:32
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 17:28
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 19:19
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 21:40
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 21:52
RE: Probleme E-Verdeck mit VIDEO! - von lemmy - 19.02.2009, 22:00
RE: Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 22:19
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 19.02.2009, 22:15
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:18
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:53
RE: Probleme E-Verdeck mit VIDEO! - von semu - 20.02.2009, 10:17
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 04:55
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 18:20
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 21.02.2009, 15:15
RE: Probleme E-Verdeck mit VIDEO! - von semu - 21.02.2009, 16:02
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 20:19
RE: Probleme E-Verdeck mit VIDEO! - von semu - 11.01.2010, 19:31
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 22:42
RE: Probleme E-Verdeck mit VIDEO! - von wiegald - 22.02.2009, 00:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 01:18
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 22.02.2009, 01:19
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.02.2009, 10:50
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 11:35
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 24.02.2009, 22:27
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 10:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 12:06
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 01.03.2009, 01:57
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 03.03.2009, 00:54
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 03.03.2009, 10:27
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 11:55
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 21:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 12:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 06.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 19:56
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 06.03.2009, 19:54
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 09:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 13:16
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 21:16
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 18:32
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:22
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 19:35
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:48
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 23:59
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 18.03.2009, 23:05
RE: Probleme E-Verdeck mit VIDEO! - von semu - 13.04.2009, 19:23
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.07.2009, 14:42
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 17.09.2009, 23:25
RE: Probleme E-Verdeck mit VIDEO! - von semu - 12.09.2009, 19:33
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 11.01.2010, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 12.01.2010, 13:31
  [Elektrisch] Verdeck Probleme JensGL 1 1.948 07.10.2025, 11:02
  Diverse Probleme mit E-Verdeck Paulneu 10 9.527 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 3.772 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 9.356 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 16.407 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 5.673 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 10.880 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 4.052 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 65.315 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 18.873 03.06.2010, 18:48
Letzter Beitrag: Mauki27
