Probleme E-Verdeck mit VIDEO!
#46
Hallo Micha,
Thanks for asking.
Nothing new really except for that now nothing is happening at all when the hood is in open position under the boot lid. just a click and then the roof lamp is flashing. But when I open the roof everthing is working as in the Video. A few times the roof lid is staying up and the roof is going down halfway into the roof and after that nada.
I have ordered parts from FOBA and will hopefully recieve them by post tomorrow. If so I will install brand new cables tomorrow and check If that curred anything.
Yes I did clear the defect code memory and after that I don't get any faulthy codes except for that the power windows is not raising from lower position when using middle dash panel button.
I have not changed anything as I get different codes depending on what stage I am in with VAG-COM. Howerever I checked with VAG-COM manually and the schalters in right and left locks are working as expected when pushing them, but I am not quite sure that the left hand side is working as it should when I maneuver the roof. It's sluggish and kindy of messy so I will clean it up and put lubricant to get it smoother.
I will do a resume after I've replaced the cables and checked if that was the problem and attach a complete VAG-COM log/listing of the individual in and outs.
Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 13:45
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 14:46
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 15:31
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 16:32
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 17:28
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 19:19
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 21:40
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 21:52
RE: Probleme E-Verdeck mit VIDEO! - von lemmy - 19.02.2009, 22:00
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 19.02.2009, 22:15
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:18
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:53
RE: Probleme E-Verdeck mit VIDEO! - von semu - 20.02.2009, 10:17
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 04:55
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 18:20
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 21.02.2009, 15:15
RE: Probleme E-Verdeck mit VIDEO! - von semu - 21.02.2009, 16:02
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 20:19
RE: Probleme E-Verdeck mit VIDEO! - von semu - 11.01.2010, 19:31
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 22:42
RE: Probleme E-Verdeck mit VIDEO! - von wiegald - 22.02.2009, 00:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 01:18
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 22.02.2009, 01:19
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.02.2009, 10:50
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 11:35
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 24.02.2009, 22:27
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 10:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 12:06
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 01.03.2009, 01:57
RE: Probleme E-Verdeck mit VIDEO! - von Stout001 - 02.03.2009, 01:00
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 03.03.2009, 00:54
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 03.03.2009, 10:27
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 11:55
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 21:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 12:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 06.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 19:56
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 06.03.2009, 19:54
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 09:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 13:16
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 21:16
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 18:32
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:22
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 19:35
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:48
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 23:59
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 18.03.2009, 23:05
RE: Probleme E-Verdeck mit VIDEO! - von semu - 13.04.2009, 19:23
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.07.2009, 14:42
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 17.09.2009, 23:25
RE: Probleme E-Verdeck mit VIDEO! - von semu - 12.09.2009, 19:33
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 11.01.2010, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 12.01.2010, 13:31
  Diverse Probleme mit E-Verdeck Paulneu 10 7.928 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 3.039 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 7.841 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 14.032 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 4.933 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 9.607 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 3.567 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 57.597 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 16.556 03.06.2010, 18:48
Letzter Beitrag: Mauki27
  Manuelles Verdeck macht Probleme shaft cabrio 16 14.682 04.02.2009, 01:43
Letzter Beitrag: shaft cabrio
