Probleme E-Verdeck mit VIDEO!
#85
Hallo Semu,
(13.04.2009, 19:23)semu schrieb: 00271 is the effect for the non opening the convertible soft top and cause could be 1) operating error or 2) invalid position of roof opening button. The elimination of 00271 you already tried out with the described actions in the thread, but try to following this order: read out of failure recorder, bring soft top into end position manually, delete failure recorder, switch ignition off and on, push roof opening button, try a complette opening/closing
semu
Thank you for the info. I have the documentaion as well on PDF. I've tried many different ways both with full closed and open top with closed/locked roof-lid. I remember when this first happened that the boot didn't open I checked the hydraulic oil and "shaked" the pump a little. After that the locks opened and the lid raised, this happened a few times but after that the same syndrom with the buzzing pump occured. It could be some wires somewhere that are defect?
I got a hold of a complete harness including the hydrualic cylinders so next weekend I will start with replacing F204 and the wires, hopefully it'll solve the problem with the boot-lid. You see, I suspect there's a connection between the upper hydraulic cylinders and the boot-lid. The documentation mention if the delay is too long the system halt, and this is what is happening as the the system totally shut of and all digits in Vag-com gives 0 0 0 0 0 0 all over. On the other hand I've had problems from the very start with the upper cylinders according to the video.
Hmmm... maybe I should make a new video so you all can hear the sound of the pump and the "boom"
Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 13:45
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 14:46
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 15:31
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 16:32
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 17:28
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 19:19
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 21:40
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 21:52
RE: Probleme E-Verdeck mit VIDEO! - von lemmy - 19.02.2009, 22:00
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 19.02.2009, 22:15
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:18
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:53
RE: Probleme E-Verdeck mit VIDEO! - von semu - 20.02.2009, 10:17
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 04:55
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 18:20
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 21.02.2009, 15:15
RE: Probleme E-Verdeck mit VIDEO! - von semu - 21.02.2009, 16:02
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 20:19
RE: Probleme E-Verdeck mit VIDEO! - von semu - 11.01.2010, 19:31
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 22:42
RE: Probleme E-Verdeck mit VIDEO! - von wiegald - 22.02.2009, 00:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 01:18
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 22.02.2009, 01:19
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.02.2009, 10:50
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 11:35
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 24.02.2009, 22:27
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 10:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 12:06
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 01.03.2009, 01:57
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 03.03.2009, 00:54
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 03.03.2009, 10:27
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 11:55
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 21:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 12:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 06.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 19:56
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 06.03.2009, 19:54
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 09:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 13:16
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 21:16
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 18:32
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:22
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 19:35
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:48
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 23:59
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 18.03.2009, 23:05
RE: Probleme E-Verdeck mit VIDEO! - von semu - 13.04.2009, 19:23
RE: Probleme E-Verdeck mit VIDEO! - von Stout001 - 13.04.2009, 20:16
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.07.2009, 14:42
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 17.09.2009, 23:25
RE: Probleme E-Verdeck mit VIDEO! - von semu - 12.09.2009, 19:33
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 11.01.2010, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 12.01.2010, 13:31
  Diverse Probleme mit E-Verdeck Paulneu 10 7.549 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 2.867 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 7.437 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 13.372 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 4.766 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 9.222 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 3.460 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 55.575 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 15.964 03.06.2010, 18:48
Letzter Beitrag: Mauki27
  Manuelles Verdeck macht Probleme shaft cabrio 16 14.150 04.02.2009, 01:43
Letzter Beitrag: shaft cabrio
