Stellmotor Heckklappe durchmessen
Hello Audiot
First of all: Very well documented and good initiative Erste Sahne !
From what I've read so far I deduce that boot lock motor V53 is O.K. but you have a problem/shortage in the wiring.
The reason beeing that always both signals (locked/unlocked) are on or off at the same time. This can be caused by a shortage or a loose (floating) ground connection !
The wiring error is located somewhere between motor V53 and control unit J256.
Pin 1,2,6 (belonging to the micro switches) of the boot lock motor connect to a green 3-fold connector in the lid.
The signal of Pin 6 is then conducted by a brown 1,0 sqm cable to another red 2-fold connector in the trunk lid. This connects to 0,5 sqm ground connection in the boot loom.
The 2 signals of Pin 1+2 end in a green 6-fold connector in the boot itself, right side.
Now several measurements have to be taken
  • Green an red connector in boot lid securely plugged
  • Is Pin 6 of the V53 plug really connected to ground with low Ohm's ?
  • Is a shortage between Pins 1+2 of V53 plug measurable, when green 6-fold connector in the boot is unplugged ?
  • Is a shortage between Pins B13+B14 of J256 plug measurable, when green 6-fold connector in the boot is unplugged ?
Remember, that with a faulty boot loom measurements can vary between open and closed state. But you said that you replaced the loom already. (With what ? Both sides ?)
Best of luck
Tux
Stellmotor Heckklappe durchmessen - von jopetzi - 22.03.2011, 22:47
RE: Stellmotor Heckklappe durchmessen - von Tux - 23.03.2011, 12:45
RE: Stellmotor Heckklappe durchmessen - von Tux - 19.07.2011, 12:05
RE: Stellmotor Heckklappe durchmessen - von Tux - 25.07.2011, 10:16
RE: Stellmotor Heckklappe durchmessen - von Tux - 11.08.2011, 14:31
RE: Stellmotor Heckklappe durchmessen - von Tux - 12.08.2011, 09:43
RE: Stellmotor Heckklappe durchmessen - von Tux - 18.08.2011, 12:11
  Verdeck - Kabelbaum Heckklappe - Empfehlung? Vossi 2 2.271 02.06.2025, 08:04
Letzter Beitrag: Vossi
  Schon wieder Kabelbaum Heckklappe Paulchen 4 4.899 18.09.2019, 08:57
Letzter Beitrag: gallex2000
  Stellmotor 8G0.959.639 Befestigung Fahrspaß 2 3.257 05.06.2019, 17:10
Letzter Beitrag: Fahrspaß
  [Manuell] Verdeck entriegelt nur bei offener(!) Heckklappe puhalomat 7 6.659 19.08.2015, 21:54
Letzter Beitrag: Audiolet
  [Elektrisch] ZV Heckklappe + Verdeck DerFabi2015 5 5.893 11.08.2015, 20:58
  Frage zu Kabelbaum Heckklappe V6-Convertible 12 14.012 03.09.2011, 20:52
Letzter Beitrag: V6-Convertible
  Belegung Stellmotor für man Verdeckdeckel muelee 0 4.100 23.07.2010, 14:50
Letzter Beitrag: muelee
  Stellmotor v53 durchmessen ... für Blöde Mongobär 13 27.153 22.04.2010, 13:37
Letzter Beitrag: Mongobär
  Silikon Kabelbaum Heckklappe wauzzz-quattro 3 5.761 28.05.2007, 20:44
Letzter Beitrag: Dirk
  Verdeck und Heckklappe Schloss Schema mateos 1 4.521 31.03.2007, 20:11
Letzter Beitrag: NiD
