Stellmotor Heckklappe durchmessen
Hi Tux, apologies, I only just now saw your answer. Thanks for your your reply!!
I indeed did the measurings between the green boot lock motor plug, but didnt have any different result.
In what I thought would be the 'defining' test, I unplugged the plug in which the right boot loom ends. So as to count out any potential malfunction of broken wires in the boot loom.
Then I took the B plug on the roof controller/j256 apart and took out the wires on pin b13 and b14 out of the plug.
Then I plugged it back into the j256 and put the ground (originating from the brown 1 sq m) first to b13 and then to b14. That gave me exactly the same faulty readings; xxxx00xx, and xxxx11xx.
That must mean the roof controller/j256 is faulty, isn't it?
Many thanks!
Stellmotor Heckklappe durchmessen - von jopetzi - 22.03.2011, 22:47
RE: Stellmotor Heckklappe durchmessen - von Tux - 23.03.2011, 12:45
RE: Stellmotor Heckklappe durchmessen - von Tux - 19.07.2011, 12:05
RE: Stellmotor Heckklappe durchmessen - von audiot - 22.07.2011, 21:48
RE: Stellmotor Heckklappe durchmessen - von Tux - 25.07.2011, 10:16
RE: Stellmotor Heckklappe durchmessen - von Tux - 11.08.2011, 14:31
RE: Stellmotor Heckklappe durchmessen - von Tux - 12.08.2011, 09:43
RE: Stellmotor Heckklappe durchmessen - von Tux - 18.08.2011, 12:11
  Stellmotor 8G0.959.639 Befestigung Fahrspaß 2 4.009 05.06.2019, 17:10
Letzter Beitrag: Fahrspaß
  [Elektrisch] ZV Heckklappe + Verdeck DerFabi2015 5 7.194 11.08.2015, 20:58
Letzter Beitrag: Audiolet
  Frage zu Kabelbaum Heckklappe V6-Convertible 12 16.138 03.09.2011, 20:52
Letzter Beitrag: V6-Convertible
  Belegung Stellmotor für man Verdeckdeckel muelee 0 4.511 23.07.2010, 14:50
Letzter Beitrag: muelee
  Stellmotor v53 durchmessen ... für Blöde Mongobär 13 29.450 22.04.2010, 13:37
Letzter Beitrag: Mongobär
  Silikon Kabelbaum Heckklappe wauzzz-quattro 3 6.667 28.05.2007, 20:44
Letzter Beitrag: Dirk
