Stellmotor Heckklappe durchmessen
Hi there Audiot
Zitat:Wann ich mitt der Stellmotor nicht angeschlossen, in der plug (die normalerweise in der Stellmotor sitzt) 6 und 1 mit einander verbinde, dan gibt VAG COM Gruppe 1, Block 1: 10110011. Wann ich 6 und 2 mit einander verbinde, dan gibt es 10111111
Wann nichts verbunden ist, gibts wieder 10110011.
-------zzzzzzziiiiipppppp-------------
By the way, with the green 6-fold connector in the boot unplugged (as well as all connectors unplugged), I get bit 5 and bit 6 both value 0. Shouldnt that be 1 and 0?
A zero (0) reading is OK in this case, since it indicates an open switch. All switches close the loop towards ground potential.
A reading of one (1) indicates the the specified switch has made contact from sensor pin on J256 to ground. The switch has pulled the 12V+ potential to 0V Ground.
Only that these two readings should have an XOR behaviour. (From engineering point of view this is a waste of hardware and connections. One signal say it all) Therefore both open/unconnected pins at the same time on the controller J256 is a "shortage to B+". One line carries the signal of the other.
Zitat:Then I took the B plug on the roof controller/j256 apart and took out the wires on pin b13 and b14 out of the plug. Then I plugged it back into the j256 and put the ground (originating from the brown 1 sq m) first to b13 and then to b14. That gave me exactly the same faulty readings; xxxx00xx, and xxxx11xx.
You measured it yourself. Seeing is believing. A ground connection on one input is immediately detected on the other one too. B13+14 are coupled by an error in the circuit.
Zitat:From your experience, is it still likely that the J256 is broken, if only one bit (V53) is wrongly measured from the whole sequence?
Yes ! It is still likely that the controller is broken. Even though only 2 sensor inputs are concerned, this corrupts the whole sequence.
I dare not say if the sensor circuitry may be repaired. No one I know of has tried yet. No one has the circuit diagram.
Other intermittent error can originate form a disrupted open/close sequence.
Best regards
Tux
Stellmotor Heckklappe durchmessen - von jopetzi - 22.03.2011, 22:47
RE: Stellmotor Heckklappe durchmessen - von Tux - 23.03.2011, 12:45
RE: Stellmotor Heckklappe durchmessen - von Tux - 19.07.2011, 12:05
RE: Stellmotor Heckklappe durchmessen - von Tux - 25.07.2011, 10:16
RE: Stellmotor Heckklappe durchmessen - von Tux - 11.08.2011, 14:31
RE: Stellmotor Heckklappe durchmessen - von Tux - 12.08.2011, 09:43
RE: Stellmotor Heckklappe durchmessen - von Tux - 18.08.2011, 12:11
  Stellmotor 8G0.959.639 Befestigung Fahrspaß 2 4.068 05.06.2019, 17:10
Letzter Beitrag: Fahrspaß
  [Elektrisch] ZV Heckklappe + Verdeck DerFabi2015 5 7.336 11.08.2015, 20:58
Letzter Beitrag: Audiolet
  Frage zu Kabelbaum Heckklappe V6-Convertible 12 16.482 03.09.2011, 20:52
Letzter Beitrag: V6-Convertible
  Belegung Stellmotor für man Verdeckdeckel muelee 0 4.554 23.07.2010, 14:50
Letzter Beitrag: muelee
  Stellmotor v53 durchmessen ... für Blöde Mongobär 13 29.654 22.04.2010, 13:37
Letzter Beitrag: Mongobär
  Silikon Kabelbaum Heckklappe wauzzz-quattro 3 6.724 28.05.2007, 20:44
Letzter Beitrag: Dirk
