Stellmotor Heckklappe durchmessen
#37
Additionally to my previous post,
I just noticed something odd. With the engine off, roof closed etc., when I pull up the handbrake, all the windows drop a few CM (just like but not quite as much as they used to when opening the roof, as they should) and the red Roof open light starts flashing in the dashboard, and the hydraulics / cylinder in the boot makes a whining noise, intermittent at the same interval as the red light flashing. So to be clear, this is without opening the roof handle, or doing anything else than just pulling up the handbrake.
Das ja man doof
Has anyone ever seen that before?
Also, the Window switch to open or close all the windows (located in the central console, at the handbrake) doesn't work anymore. Not opening and not closing. When I push it I can hear a relais clicking, but nothing happens.
All windows work well individually from the window switches in the door.
I was wondering, should I reset something about the car or controller, now i've installed the other j256 / Roof controller? And how?
Thanks!
Stellmotor Heckklappe durchmessen - von jopetzi - 22.03.2011, 22:47
RE: Stellmotor Heckklappe durchmessen - von Tux - 23.03.2011, 12:45
RE: Stellmotor Heckklappe durchmessen - von Tux - 19.07.2011, 12:05
RE: Stellmotor Heckklappe durchmessen - von Tux - 25.07.2011, 10:16
RE: Stellmotor Heckklappe durchmessen - von Tux - 11.08.2011, 14:31
RE: Stellmotor Heckklappe durchmessen - von Tux - 12.08.2011, 09:43
RE: Stellmotor Heckklappe durchmessen - von audiot - 16.08.2011, 17:01
RE: Stellmotor Heckklappe durchmessen - von Tux - 18.08.2011, 12:11
  Verdeck - Kabelbaum Heckklappe - Empfehlung? Vossi 2 2.268 02.06.2025, 08:04
Letzter Beitrag: Vossi
  Schon wieder Kabelbaum Heckklappe Paulchen 4 4.895 18.09.2019, 08:57
Letzter Beitrag: gallex2000
  Stellmotor 8G0.959.639 Befestigung Fahrspaß 2 3.256 05.06.2019, 17:10
Letzter Beitrag: Fahrspaß
  [Manuell] Verdeck entriegelt nur bei offener(!) Heckklappe puhalomat 7 6.652 19.08.2015, 21:54
Letzter Beitrag: Audiolet
  [Elektrisch] ZV Heckklappe + Verdeck DerFabi2015 5 5.885 11.08.2015, 20:58
  Frage zu Kabelbaum Heckklappe V6-Convertible 12 14.009 03.09.2011, 20:52
Letzter Beitrag: V6-Convertible
  Belegung Stellmotor für man Verdeckdeckel muelee 0 4.097 23.07.2010, 14:50
Letzter Beitrag: muelee
  Stellmotor v53 durchmessen ... für Blöde Mongobär 13 27.144 22.04.2010, 13:37
Letzter Beitrag: Mongobär
  Silikon Kabelbaum Heckklappe wauzzz-quattro 3 5.760 28.05.2007, 20:44
Letzter Beitrag: Dirk
  Verdeck und Heckklappe Schloss Schema mateos 1 4.512 31.03.2007, 20:11
Letzter Beitrag: NiD
