Roof problem
(22.07.2015, 08:52)Tux schrieb: Hi Denis
First let me tell you that checking the Oil level was a good first step. Apart from that you have already excluded many factors like hydraulic cylinder.
Now, you have to change the right wiring loom leading into the trunk lid. Most probably one or another wire will be broken.
Background: the actor inside trunk lid V53 has 2 micro switches, that must issue correct values. If the wiring loom is damaged a) signal will not be transmitted, b) V53 can be demaged internally due to short circuit.
Best regards
Tux
Wow, i didn't think that central lock used(v53).  When i close a door by key, rear door doesn't close. And necessary close it separately.
Best regards
Denis 116Rus
Roof problem - von Denis 116Rus - 21.07.2015, 16:48
RE: Roof problem - von Lagebernd - 22.07.2015, 08:14
RE: Roof problem - von Denis 116Rus - 22.07.2015, 10:34
RE: Roof problem - von blue-elise - 22.07.2015, 08:33
RE: Roof problem - von Tux - 22.07.2015, 08:52
RE: Roof problem - von Denis 116Rus - 22.07.2015, 10:44
RE: Roof problem - von Denis 116Rus - 26.07.2015, 20:15
  [Problem] Manuel roof problem not broken cabels? Benjaminja 2 3.237 29.07.2015, 21:13
Letzter Beitrag: Audiolet
  electric roof steven2.8 7 9.588 01.07.2010, 15:46
Letzter Beitrag: Grappa
