Verdeck steuergerät reparieren DIY
I read this day's some topics here and it's clear...the control unit is not that easy to work on. I started to repair the cruise control units from old Mercedes, like w123, w126, R107..., and it's not that complicated. I even built a bench test to check the functionality and it's working very well.
Inside the amplifier (control unit) some capacitors are dry and is easy to be changed, some soldering to motherboard and it's ready.
I tried to open the roof control unit from Audi and ... all components are newer, smaller and with higher complexity. Nothing to do.... I tried to soldering all connection from the circuit, but without any result.
Is not that easy like I thought, but I'm sure that if someone with more knowledge in electronics will dedicate a little more time, can easily repair this control unit. At the end, being so many from old generations (without A), I suppose that the problem is has to be the same for all. Definitely is some cheap electronic parts for which the costs is a few euros.
I have some non functional control unit and I will try to change some components. I will post here if I have some good results.
best regards
Luciano
RE: Verdeck steuergerät reparieren DIY - von Lucian_kel - 13.02.2022, 22:04
Verdeck steuergerät reparieren DIY - von lemmy - 15.03.2022, 23:52
  Verdeck-Steuergerät J256 (Ersatzteilnummer 8G0 959 255) reparieren black_cab 4 4.257 05.10.2025, 12:26
Letzter Beitrag: black_cab
  F203/F204 Kabelbruch, wie reparieren Thorsten42 2 4.646 30.11.2024, 21:44
Letzter Beitrag: Thorsten42
  [Manuell] Verdeckkasten entriegelt nur nach Steuergerät ab und anklemmen chr0815 15 17.957 28.02.2017, 11:23
Letzter Beitrag: chr0815
  [Problem] verdekkasten steuergerät Guido 1411 4 7.991 17.02.2015, 20:04
  Steuergerät abgeraucht??? 01richie 14 17.637 04.06.2014, 18:55
Letzter Beitrag: 01richie
  [Info] Verdeck-Steuergerät reparieren helge101 4 10.202 15.05.2013, 10:32
Letzter Beitrag: Maveric
  [Elektrisch] Verdeck will nach neuem Steuergerät immer noch nicht ... helge101 12 18.593 08.04.2013, 22:21
Letzter Beitrag: helge101
  Steuergerät Verdeck defekt? Wer repariert die, bzw. hat einer noch eines rumliegen? Lartin10 28 38.024 14.10.2012, 22:07
  Frage zum Steuergerät bei elektrischem Verdeck hollo1612 14 18.730 07.07.2011, 13:28
Letzter Beitrag: Jenkins
  Verdeckgestänge reparieren? spenc 3 8.493 05.12.2010, 12:37
Letzter Beitrag: spenc
