Öltemperatur- und Druckmessgeräte
Good morning everyone,
I have read the various posts on this topic and hope that someone with experience can explain a few points to me.
My oil temperature and oil pressure gauges are showing incorrect readings; the pressure always shows the maximum value, but the temperature never shows. From what I've read, this indicates a problem with the sensors or wiring. The battery voltage sensor shows the correct readings.
I purchased the correct oil temperature sensor and will install it. However, I'm hoping someone can confirm the part numbers for the oil pressure sensors for the 1.8ADH engine. I'm surprised that there seem to be different sensors!
Thank you all.
Chris
Öltemperatur- und Druckmessgeräte - von Chris from Wales - 31.05.2025, 09:42
  Kühlmittel- und Öltemperatur Benz 12 13.024 28.07.2015, 12:49
  Öltemperatur Anzeige ohne Funktion Manurix 7 12.026 19.01.2015, 16:49
Letzter Beitrag: Manurix
  Öltemperatur NG beetlejuicebln 14 22.726 23.05.2014, 20:50
  [Problem] Öltemperatur Steigt sehr hoch bei Vollgas Dikell2604 10 18.778 27.02.2014, 15:31
Letzter Beitrag: Dikell2604
  Öltemperatur beim NG bis 170°C Surs15 7 12.950 14.02.2012, 14:39
Letzter Beitrag: Surs15
  Motortemperatur seltsam, aber Öltemperatur OK ManuCab 7 15.475 07.09.2011, 09:01
  Niedrige Kühler- und Öltemperatur!? Wiesel10 34 71.969 05.05.2011, 22:33
Letzter Beitrag: StefanR.
  Öltemperatur - wann wird es kritisch semu 16 43.238 01.06.2009, 20:11
Letzter Beitrag: semu
  Wasser-und Öltemperatur Bobbycar123 21 33.487 26.09.2008, 23:25
Letzter Beitrag: Maveric
  Öltemperatur MrWhy 2 6.897 31.07.2008, 12:27
Letzter Beitrag: Sechserpack
