Themen: 1
Baujahr: 1997
Hubraum (CCM): 2600
I have a problem with electric roof and i find some information on this forum, but only German, not English. But, maybe somebody can help me.
I have old 1997 Audi Cabrio and end of last summer my car electric roof stop working. If i try use that, only warning light blinking, nothing more.
At today (first warm day in Finland) i take out my Cabrio and connect it to VAG-COM unit. I find that codes:
Address 26: Auto Roof Labels: None
Part No: 8G0 959 255 A
1 Fault Found:
00271 - See Repair Group 01
35-10 - - - Intermittent
Then i take information from measurement unit when roof was closed, hand brake on and ready to open roof. Bytes was that kind:
Address 26: Auto Roof (8G0 959 255 A)
19:25:01 Group 001
00100100 Bin. Bits
00100101 Bin. Bits
00000100 Bin. Bits
11 00 Bin. Bits
Can anybody find, what is wrong?
Themen: 3
Baujahr: 1992
Hubraum (CCM): 2309
Motorkennbuchstabe: NG
Hi Catiska,
first of all I would like to say welcome u to our forum!!!
There can be different failures, a cable can be broken for example or the roof has benn not fully closed (operatorfailure)???
What is with the error code, has it been deleted???
Best regards
Sascha
92´er 5-Zylinder, KN-Matte, BN-Pipes ab Kat, KW Gewinde, 9x16 BBS RS LK 4x108 absolute Rarität!!!
Sascha
Themen: 1
Baujahr: 1997
Hubraum (CCM): 2600
Hi Sascha,
Thanks, that is nice forum!!
I didn't found any other error codes, only that one...
But, in measurement block (first block first byte) is wrong, what that byte mean? "F200 verriegelt"??? That should be YES (JA) but it is NO (NEIN)...
Themen: 3
Baujahr: 1992
Hubraum (CCM): 2309
Hmmm, have u check the "Mikroschalter"???
Look at this link: http://www.audicabrio.info/support/index...artlang=de
Sascha
Themen: 1
Baujahr: 1997
Hubraum (CCM): 2600
Is "mikrochalter" a microswitch? Maybe right side microswitch on roof cover?
Themen: 9
Baujahr: 1994
Hubraum (CCM): 1985
Mikroschalter translated ist microswitch, thats right.
To your second question, i can´t say anything(I dont know it).
Ich: Mann, Bj.85, Herz, 4l/Std, SF, Leder: beige mit tendenz zu braun, M-Hut, DWA, orig. Adidas Schuhe(42er Besohlung)
Themen: 65
Baujahr: 1999
Hubraum (CCM): 1800
Motorkennbuchstabe: ADR
43 Danke aus 36 posts
Hi Catiska,
welcome on this Board.
I understand correct that your Roof don`t work comlpetly (Roof Switch pushed) and the Warning Light flashing in this Moment?
It is also possible that the Problem comes from the RIGHT CABLE HARNESS on your Luggage Door. On my Car it was the same Problem and the Cables was broken inside of the Harness. You can it repair temporarly but a replacement it better.
A Sec Problem is the Mircroswitch of the Hook from your Roof Cap. Please Check that that the Holder from the Roof Cap is correctly closed in the Hook. (L/H and R/H). The Hook is under the little Black Cap on your Car. This Black Cap is closed in Roof Open Position and Open when it is closed.
Nice Greats Andreas
Realname: Andreas
Themen: 1
Baujahr: 1997
Hubraum (CCM): 2600
(14.05.2010, 13:29)Cabriofreak schrieb: It is also possible that the Problem comes from the RIGHT CABLE HARNESS on your Luggage Door. On my Car it was the same Problem and the Cables was broken inside of the Harness. You can it repair temporarly but a replacement it better.
Thanks a lot for everyone!!!
That work, problem was right cable harnes... It is now repaired temporarly but i should order a new one.
-Ari
Themen: 65
Baujahr: 1999
Hubraum (CCM): 1800
(14.05.2010, 18:11)Catiska schrieb: (14.05.2010, 13:29)Cabriofreak schrieb: It is also possible that the Problem comes from the RIGHT CABLE HARNESS on your Luggage Door. On my Car it was the same Problem and the Cables was broken inside of the Harness. You can it repair temporarly but a replacement it better.
-Ari
That is fine.
You can order a new one by Audi but the Price is high. In Germany ca. 120€ and 2 Years Garantee.
You can order a Repairkit from the Company FOBA The Price of this Repairkit is ca. 50€ plus Shipping. You have 10 Years Garantee.
Send a E-mail on t.forster@fobo-germering.de or call hin 004915201900896.
Nice Greats Andreas
Realname: Andreas
Themen: 1
Baujahr: 1997
Hubraum (CCM): 2600
