Stellmotor Heckklappe durchmessen
#33
Hi Tux, sorry for my confusing wording.
What I meant was that with the boot loom / everything plugged in, I unplugged the B plug off the J256, and I measured between pin 13 of Plug B and GND, and between pin 14 of Plug B and GND. This to check if the Boot lock motor switch was working and uninterrupted in both open and closed state, which is the case. Also, there is no shortage between the cables between the Boot lock motor and the B plug at J256.
Just to double (triple..) check if the looms are ok.
So as you suggested in entry #21, there are no shorts between pin1 and 2 on V53, no shorts in the Cable, and no shorts on b13 and b14 on J256.
Thanks,
ps. where would one find a J256 (8G0 959 255)? I called to 10 breakers and nothing on ebay. I suppose new from Audi would be pricey.
Stellmotor Heckklappe durchmessen - von jopetzi - 22.03.2011, 22:47
RE: Stellmotor Heckklappe durchmessen - von Tux - 23.03.2011, 12:45
RE: Stellmotor Heckklappe durchmessen - von Tux - 19.07.2011, 12:05
RE: Stellmotor Heckklappe durchmessen - von Tux - 25.07.2011, 10:16
RE: Stellmotor Heckklappe durchmessen - von Tux - 11.08.2011, 14:31
RE: Stellmotor Heckklappe durchmessen - von Tux - 12.08.2011, 09:43
RE: Stellmotor Heckklappe durchmessen - von audiot - 12.08.2011, 17:06
RE: Stellmotor Heckklappe durchmessen - von Tux - 18.08.2011, 12:11
  Stellmotor 8G0.959.639 Befestigung Fahrspaß 2 3.843 05.06.2019, 17:10
Letzter Beitrag: Fahrspaß
  [Elektrisch] ZV Heckklappe + Verdeck DerFabi2015 5 6.878 11.08.2015, 20:58
Letzter Beitrag: Audiolet
  Frage zu Kabelbaum Heckklappe V6-Convertible 12 15.744 03.09.2011, 20:52
Letzter Beitrag: V6-Convertible
  Belegung Stellmotor für man Verdeckdeckel muelee 0 4.437 23.07.2010, 14:50
Letzter Beitrag: muelee
  Stellmotor v53 durchmessen ... für Blöde Mongobär 13 28.987 22.04.2010, 13:37
Letzter Beitrag: Mongobär
  Silikon Kabelbaum Heckklappe wauzzz-quattro 3 6.489 28.05.2007, 20:44
Letzter Beitrag: Dirk
