Wheel suspension, how much to lower?
Today I put on new 17" wheels on my daughters cabrio. So far so good. But there is too much space between the wheel arch and the wheel, specially back. I have to buy new springs but don't know how much to lower the car. Is 30mm enough to get a nice smooth look?
Do I have to change the struts as well or is it enough to change springs?
[Bild: audiwheels.jpg]
Hi Stout001,
please have a look on the gallery with the member cars. There are a lot of pictures and descriptions, which springs the members have built in their cars. For example look at my pics under the nickname "vnjochen" - I have 40 mm at the front and 30 mm at the back.
Greetings
Jochen
Wenn du einmal akzeptierst hast, dass sich das Universum in die Ewigkeit ausdehnt,
ist es dir egal, ob du Schottenmuster mit Streifen kombinierst.
2,8 l, 215/45 17 auf 8x17 RH Phönix black edition, 40 mm Spurverbreiterung je Achse, AP Federn 40/30 mm, Fox-ESD
[Bild: 6qnu-g-c74d.jpg] [Bild: 6qnu-b-6512.jpg]
Have another look here:
http://www.audicabrio.info/co/showthread...and+thread
you will find many examples.
Greets,
kAlle
kAlle
Meine Audis:
A3, Typ 8P, 2004
Cabrio, Typ 89, 1997
Coupé S, Typ C1, 1971
[Bild: b4xgeyyzc9euazynp.jpg]
Hi Stout!
And...by the way...what you can see below are 30mm with 17''.
Greets from Hang Over,
DCool n KryptCool n
[Bild: IMG_8757a.JPG]
