Verdeck change tutorial - Druckversion +- Audi Cabriolet Forum (https://www.audi-cabrio-club.info/forum) +-- Forum: Audi Cabriolet (https://www.audi-cabrio-club.info/forum/forumdisplay.php?fid=1) +--- Forum: Pflege des Cabriolets (https://www.audi-cabrio-club.info/forum/forumdisplay.php?fid=76) +---- Forum: Verdeck (https://www.audi-cabrio-club.info/forum/forumdisplay.php?fid=80) +---- Thema: Verdeck change tutorial (/showthread.php?tid=38106) |
Verdeck change tutorial - Lucian_kel - 20.04.2023 Hello everyone, I recently bought a new soft top for my Audi 89 cabrio from Osnabrück cabrio zentrum, and I received also a instalation guide. The instructions are in German and I really don't understand what is written there, only the photos. Does anyone know where I can find a tutorial to change the soft top? I searched here on the forum, but won't found anything. Many thanks Best regards A Lucian RE: Verdeck change tutorial - semu - 20.04.2023 Hey Lucian, don’t know where to find the correct tutorial. But I am frequently using DeepL.com Pro version. You can upload pdf and it’s getting very well translated by AI teaches bases. 30 days it’s a free trial … maybe an alternative for your problem Kind regards semu RE: Verdeck change tutorial - Käptn Haddock - 24.04.2023 Hi Lucian, I would recommend to ask the Osnabrück Cabrio centre for an installation instruction in English; they should have it. Another hint if you intend to replace the soft top: You can expect rust on the frame where it was in touch with the canvas, further I remember there is some soft material on the front and rear frames with rust underneath. After removal of the skin I carefully covered the cockpit with blankets, cleaned the frame and grinded the rust (in the other hand a vac cleaner). I painted the grinded spots on the beams with black 'Brantho-Korrux 3in1' (for example) using a brush, because the frame will most likely not be seen again. Cheerio - Christoph RE: Verdeck change tutorial - Lucian_kel - 24.04.2023 Ok, thank you all for the tips. @semu at the end... it's not very complicated to work on. It's important to have time, work organised and make a lot of photos. @Christopher I will try to ask for a english installation guide. You right, already found rust on the rear side (the metal under the rear window) and cleaned, treated with rust convertor and painted in black. Now I will try to change the elastic band, because is really in bad shape. Tomorrow I will make some photos. Thanks again, Best regards A. Lucian |
