[Elektrisch] Elektrisch kaleche FEHLT !?!?
Sorry for making this post in English!
My Hood is suddenly causing problems - just when the sunshine has arrived!
The local garages are not able to solve the problem - no failure codes are present!
When the rear window is lifted upwards and the box cover are opened upwards the box cover suddenly Looses power and the stops....
Please watch video: http://youtu.be/_VONOLJuq5E
Your advices how to solve or maybe a recommendation of a very good garage/shop with experience for this matter in Northern Germany will be higly appriciated!
Vielen dank Au Backe
Kloster
Good morning,
I think there is less of oil in the pump. Have you checked that?
Greetz!
hi kloster,
welcome in this board, nice car, only a bit to young... anyway...
pleas tell us, what did you done till yet. what services, which parts would chance...
best whishes,
chris
What have been done so far is:
* New battery to get the needed AMP.
* Two new swtches in the front because a failure code suddenly occured once.... Even though there were no problems in the front area.
* System reset.
* A lot of walking around the car wondering what to do ;-)
I have told the garage NOT to replace further parts before they have a certain reason....
Ralph: Thanks for your input - sound absolutely relevant! How do I check the oil in the pump? Where is the oil container located.... Is it a job for a handyman?
HI,
open the trunk, look right side. On the floor there is a service-point. You can open the carpet and the you'll see the pump. The Oil has to be at maximum wehen the roof ist completely opened.
Hi Kloster,
seems to be a problem which is known at A4 convertible.
Please look at: This is a link
Only in german - but if you post your question there in english, you will get help very soon.
Registration is necessary and a short introduction of you is very welcome there.
Good luck.
Uwe
(09.05.2014, 08:52)Ralph schrieb: HI,
Hi Ralph,
this works at Typ 89 Cab, at A4 you have to deinstall the cover on the right side of the trunk completely...
Uwe
Hi Uwe and Ralph,
Thanks for your great fast help! I will try this in the weekend and post the result!
Great experience to find such people on a completely new forum for me!
Have a nice weekend!
Kloster
Ash on my head!
I haven't seen, that he owns an A4 Cabrio, not an T89! Sorry for that!
Hi there
please refer to this link: Check hydraulic oil level
Hej kloster,
at gøre Uwe post mere forståeligt for dig, her hurtige tider i dansk, håber ingen er ond. Så problem synes at være donor G356. Den bør du udskifte dem og derefter slette fejlen hukommelse, så den øverste bør arbejde igen. Del antallet af encoderen er 8H0 959 613A
ENGLISCH:
Hello Kloster,
to make Uwe's post more understandable for you, here in english. So the problem seems to be the donor G356.You should replace them and then delete the error memory, then the top should work again. Part number of the encoder is the 8H0 959 613A
hilsen Manny - google Übersetzer
Gruß Manny
Autofotografie
Veränderungen:
  Verdeckgestänge von elektrisch / hydrauslisch auf manuell gamml1337 7 3.763 06.10.2019, 15:16
Letzter Beitrag: aucabdriver
  Erfahrungsbericht Umbau des manuellen Verdecks auf elektrisch spider0709 3 2.592 01.06.2018, 08:21
Letzter Beitrag: Burns
  Cabrio mit Hardtop gekauft, VERDECK FEHLT fünfzylinderkrank 17 19.998 06.07.2011, 07:44
Letzter Beitrag: fünfzylinderkrank
  Verdeck elektrisch manuell schliessen fremdermann1 2 6.344 04.03.2011, 12:40
Letzter Beitrag: fremdermann1
  Verdeck elektrisch -problem audiv6 8 8.168 08.10.2010, 23:07
Letzter Beitrag: Jenkins
  Endschalter für das manuelle Verdeck fehlt beim E-Verdeck tt-bandit 7 7.165 02.03.2010, 20:32
  Verdeck bleibt stehen - Schraube fehlt saraph 3 4.109 01.06.2009, 20:52
Letzter Beitrag: Owe
  Verdeck öffnet nicht mehr elektrisch Cabriolix 4 4.722 08.07.2008, 08:37
Letzter Beitrag: Cabriolix
  Neue Heckscheibe oder auf elektrisch Verdeck umbauen ???? Stimpy 14 8.483 26.04.2007, 02:16
Letzter Beitrag: Alex
