Probleme E-Verdeck mit VIDEO!
#67
Moin Thilo
(09.03.2009, 13:16)Tux schrieb: Hi Lars
We have to differentiate between relays for operation and the corresponding control unit.
The latter takes 2 places (5+6).
As mentioned before one relay is for lifting (16) and one relay is for lowering power windows (13).
But only driver window. All other three windows are powerd by relays, that are found behind rear set upholstry.
Okey. I understand.
What I don't understand though is where the 4 x window button in the middle control panel is connected to. Is this what you call "the control unit"?
All my windows are working excellent when pressing the buttons on the door, they go down and they go up.
They are working and lowering when opening the hood. and they work if I push down in the middle control panel. But they don't work if I want to raise them from the middle control panel button. I just hear a strong click. The click comes from the right relay #203 under the steeringshaft. I've cleaned up both 203 relays and changed places, still it won't work.
I read a lot about this in the commuity yesterday and a common fault is obviously cold soldering. I will check that today. But I also read posts about other relays involved. 367, 363, 343, 20 and 21. I will try to locate them today and have a check.
Is there any complete FAQ or listing on where all relays are situated or what they do? If not I may go over them all in the car and make a FAQ out of it Cool But as I understand it's all also year dependent?
UPDATE concerning the roof top. Suddently the roof lid is working again and believe it or not, the bootlid stayed up while the back or the roof went down in the roof lid but as I don't have the gas struts in place the edge of the roof bumped into the lid. Today I'll get the gas struts for the roof lid and hopefully the lid stays up when they are mounted.
Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 13:45
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 14:46
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 15:31
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 16:32
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 17:28
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 19:19
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 21:40
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 21:52
RE: Probleme E-Verdeck mit VIDEO! - von lemmy - 19.02.2009, 22:00
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 19.02.2009, 22:15
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:18
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:53
RE: Probleme E-Verdeck mit VIDEO! - von semu - 20.02.2009, 10:17
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 04:55
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 18:20
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 21.02.2009, 15:15
RE: Probleme E-Verdeck mit VIDEO! - von semu - 21.02.2009, 16:02
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 20:19
RE: Probleme E-Verdeck mit VIDEO! - von semu - 11.01.2010, 19:31
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 22:42
RE: Probleme E-Verdeck mit VIDEO! - von wiegald - 22.02.2009, 00:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 01:18
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 22.02.2009, 01:19
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.02.2009, 10:50
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 11:35
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 24.02.2009, 22:27
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 10:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 12:06
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 01.03.2009, 01:57
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 03.03.2009, 00:54
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 03.03.2009, 10:27
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 11:55
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 21:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 12:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 06.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 19:56
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 06.03.2009, 19:54
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 09:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 13:16
RE: Probleme E-Verdeck mit VIDEO! - von Stout001 - 09.03.2009, 14:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 21:16
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 18:32
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:22
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 19:35
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:48
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 23:59
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 18.03.2009, 23:05
RE: Probleme E-Verdeck mit VIDEO! - von semu - 13.04.2009, 19:23
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.07.2009, 14:42
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 17.09.2009, 23:25
RE: Probleme E-Verdeck mit VIDEO! - von semu - 12.09.2009, 19:33
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 11.01.2010, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 12.01.2010, 13:31
  [Elektrisch] Verdeck Probleme JensGL 1 2.843 07.10.2025, 11:02
  Diverse Probleme mit E-Verdeck Paulneu 10 11.711 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 4.620 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 11.409 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 19.680 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 6.416 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 12.601 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 4.544 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 76.847 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 22.272 03.06.2010, 18:48
Letzter Beitrag: Mauki27
