Themen: 175
Baujahr: 1993
Hubraum (CCM): 2309
43 Danke aus 33 posts
Good morning,
I think there is less of oil in the pump. Have you checked that?
Greetz!
Themen: 17
Baujahr: 1992
Hubraum (CCM): 2,3
29 Danke aus 27 posts
hi kloster,
welcome in this board, nice car, only a bit to young... anyway...
pleas tell us, what did you done till yet. what services, which parts would chance...
best whishes,
chris
Themen: 1
Fahrzeug: Audi A4 Cabrio
Baujahr: 02/2002
Hubraum (CCM): 3000
1 Danke aus 1 posts
What have been done so far is:
* New battery to get the needed AMP.
* Two new swtches in the front because a failure code suddenly occured once.... Even though there were no problems in the front area.
* System reset.
* A lot of walking around the car wondering what to do ;-)
I have told the garage NOT to replace further parts before they have a certain reason....
Ralph: Thanks for your input - sound absolutely relevant! How do I check the oil in the pump? Where is the oil container located.... Is it a job for a handyman?
Themen: 175
Baujahr: 1993
Hubraum (CCM): 2309
HI,
open the trunk, look right side. On the floor there is a service-point. You can open the carpet and the you'll see the pump. The Oil has to be at maximum wehen the roof ist completely opened.
Themen: 1
Baujahr: 02/2002
Hubraum (CCM): 3000
1 Danke aus 1 posts
Hi Uwe and Ralph,
Thanks for your great fast help! I will try this in the weekend and post the result!
Great experience to find such people on a completely new forum for me!
Have a nice weekend!
Kloster
Themen: 175
Baujahr: 1993
Hubraum (CCM): 2309
Ash on my head!
I haven't seen, that he owns an A4 Cabrio, not an T89! Sorry for that!
Themen: 104
Baujahr: 1993
Hubraum (CCM): 2.8
196 Danke aus 130 posts
Hej kloster,
at gøre Uwe post mere forståeligt for dig, her hurtige tider i dansk, håber ingen er ond. Så problem synes at være donor G356. Den bør du udskifte dem og derefter slette fejlen hukommelse, så den øverste bør arbejde igen. Del antallet af encoderen er 8H0 959 613A
ENGLISCH:
Hello Kloster,
to make Uwe's post more understandable for you, here in english. So the problem seems to be the donor G356.You should replace them and then delete the error memory, then the top should work again. Part number of the encoder is the 8H0 959 613A
hilsen Manny - google Übersetzer
Gruß Manny
Autofotografie
Veränderungen:
IMSA GTO-Folierung; Facelift Umbau; Boschmann und Hifonics Lautsprecher samt Verstärker; Audi Navigation Plus DX mit TMC-Box mit Multi-Media Interface, Dietz 1212/B, Zemex DVB-T D90 2G und Parrot CK3100;
