Free air oder kiste?
#32
Ich hab da jetzt auch nochmal ne Frage an die Experten unter euch. Leider hab ich die Daten meines Subs nur als PDF und weiß nicht wie ich das hier einbinden soll, damit es jeder lesen kann, daher muß ich es leider so machen. Jeweils der mittlere Wert trifft zu, ich hab einen EX10!
EX SERIES II SUBWOOFER SPECIFICATIONS
EX8 EX10 EX12
THIELE/SMALL PARAMETERS
Type subwoofer subwoofer subwoofer
Driver Complement 8" 10" 12"
Nominal Impedance 4ohms 4ohms 4ohms
Frequency response 20-300Hz 20-400Hz 20-500Hz
Fs (Hz) 44.64Hz 32.47Hz 24.47Hz
Re 3.73 ohms 3.34 ohms 3.38 ohms
Le 1.57 mH 1.55 mH 1.40 mH
Qms 11.43 8.27 8.14
Qes 0.57 0.48 0.31
Qts 0.54 0.45 0.30
Vas (cubic feet) 0.66 ft3 1.59 ft3 4.72 ft3
Vas (liters) 18.51L 44.56L 132.02L
Power Handling (watts continuous) 125watts 150watts 150watts
Power Handling (watts peak) 300watts 400watts 400watts
Sensitivity (SPL at 1 watt / 1 meter) 90 dB 92 dB 93 dB
Xmax (inches) 0.177 in. 0.177 in. 0.177 in.
Xmax (millimeters) 4.5 mm 4.5 mm 4.5 mm
Voicecoil Diameter 1.5 in. 2.0 in. 2.0 in.
Mounting depth (inches) top mount 3 7/8" 4 11/16" 5 3/8"
(millimeters) 85 mm 120 mm 135 mm
Mounting depth (inches) bottom mount 4 1/4" 5 1/16" 5 3/4"
(millimeters) 110 mm 130 mm 145 mm
Mounting diameter (inches) 7 1/8" 9 1/16" 10 7/8"
(millimeters) 180 mm 230 mm 276 mm
RECOMMENDED ENCLOSURES
Sealed
Sealed volume(cubic feet) .5 ft3 .65 ft3 .95 ft3
(liters) 14.2 L 18.4 L 26.9 L
Ported
Ported volume(cubic feet) .75 ft3 1.0 ft3 1.25 ft3
(liters) 21.2 L 28.3 L 35.4 L
Port diameter (inches) 3 in. 3 in. 4 in.
(millimeters) 75 mm 75 mm 100 mm
Port length (inches) 10 1/4" 11 1/4" 12 5/16"
(millimeters) 255 mm 280 mm 305 mm
Tuning frequency (Hz) 45Hz 38 Hz 40 Hz
Bandpass
Bandpass total volume (cubic feet) 1.1 ft3 1.1 ft3 1.5 ft3
(liters) 31.1 L 31.1 L 42.4 L
Front chamber volume (cubic feet) .70 ft3 .50 ft3 .75 ft3
(liters) 19.8 L 14.2 L 21.2 L
Back chamber volume (cubic feet) .38 ft3 .60 ft3 .72 ft3
(liters) 10.8 L 17.0 L 20.4 L
Port length (inches) 12 3/8" 9 7/8" 19 3/16"
(millimeters) 310 mm 250 mm 480 mm
Back chamber tuning frequency (Hz) 58 Hz 51 Hz 46 Hz
Z. Zt. als Freeair verbaut! ist das richtig so, oder wäre der vond en Werten gesehen für ne andere Lösung besser geeignet?
Free air oder kiste? - von Vibesy - 20.07.2008, 12:58
RE: Free air oder kiste? - von Karsten S - 20.07.2008, 13:56
RE: Free air oder kiste? - von Vibesy - 20.07.2008, 14:36
RE: Free air oder kiste? - von RandyAndy - 20.07.2008, 22:39
RE: Free air oder kiste? - von soundjunk - 20.07.2008, 22:39
RE: Free air oder kiste? - von Vibesy - 20.07.2008, 22:53
RE: Free air oder kiste? - von soundjunk - 20.07.2008, 23:15
RE: Free air oder kiste? - von Vibesy - 20.07.2008, 23:36
RE: Free air oder kiste? - von Ralph - 21.07.2008, 09:20
RE: Free air oder kiste? - von Ralph - 21.07.2008, 11:52
RE: Free air oder kiste? - von Vibesy - 21.07.2008, 12:09
RE: Free air oder kiste? - von Ralph - 21.07.2008, 12:14
RE: Free air oder kiste? - von Maveric - 21.07.2008, 12:49
RE: Free air oder kiste? - von RandyAndy - 21.07.2008, 14:33
RE: Free air oder kiste? - von Vibesy - 21.07.2008, 17:34
RE: Free air oder kiste? - von Tux - 21.07.2008, 17:59
RE: Free air oder kiste? - von Vibesy - 21.07.2008, 21:16
RE: Free air oder kiste? - von Matti - 22.07.2008, 00:13
RE: Free air oder kiste? - von Tux - 22.07.2008, 11:53
RE: Free air oder kiste? - von VIP__;) - 28.07.2008, 01:20
RE: Free air oder kiste? - von Ralph - 22.07.2008, 12:11
RE: Free air oder kiste? - von ahaspharos - 22.07.2008, 16:56
RE: Free air oder kiste? - von Vibesy - 22.07.2008, 17:26
RE: Free air oder kiste? - von Dancecore - 22.07.2008, 19:06
RE: Free air oder kiste? - von Cabrio-Poser - 22.07.2008, 19:31
RE: Free air oder kiste? - von ahaspharos - 22.07.2008, 20:23
RE: Free air oder kiste? - von Vibesy - 22.07.2008, 20:52
RE: Free air oder kiste? - von Ralph - 23.07.2008, 07:49
RE: Free air oder kiste? - von ahaspharos - 22.07.2008, 22:48
RE: Free air oder kiste? - von Vibesy - 23.07.2008, 13:15
RE: Free air oder kiste? - von Ralph - 29.07.2008, 08:57
RE: Free air oder kiste? - von Ralph - 29.07.2008, 11:41
RE: Free air oder kiste? - von Tux - 29.07.2008, 13:56
RE: Free air oder kiste? - von Ralph - 29.07.2008, 14:05
RE: Free air oder kiste? - von Tux - 29.07.2008, 16:16
RE: Free air oder kiste? - von Ralph - 29.07.2008, 16:23
RE: Free air oder kiste? - von VIP__;) - 29.07.2008, 19:59
RE: Free air oder kiste? - von Ralph - 30.07.2008, 14:48
RE: Free air oder kiste? - von VIP__;) - 31.07.2008, 00:34
RE: Free air oder kiste? - von Ralph - 31.07.2008, 15:53
RE: Free air oder kiste? - von VIP__;) - 31.07.2008, 18:53
RE: Free air oder kiste? - von Ralph - 01.08.2008, 09:05
RE: Free air oder kiste? - von VIP__;) - 01.08.2008, 12:09
RE: Free air oder kiste? - von Ralph - 01.08.2008, 12:55
RE: Free air oder kiste? - von ahaspharos - 01.08.2008, 15:33
RE: Free air oder kiste? - von H;o)lli - 01.08.2008, 15:42
RE: Free air oder kiste? - von ahaspharos - 01.08.2008, 16:37
RE: Free air oder kiste? - von Ralph - 04.08.2008, 10:45
RE: Free air oder kiste? - von Tux - 04.08.2008, 11:19
RE: Free air oder kiste? - von Ralph - 04.08.2008, 11:42
RE: Free air oder kiste? - von Tux - 04.08.2008, 14:40
RE: Free air oder kiste? - von Ralph - 04.08.2008, 15:12
RE: Free air oder kiste? - von VIP__;) - 04.08.2008, 21:58
RE: Free air oder kiste? - von Ralph - 06.08.2008, 14:42
RE: Free air oder kiste? - von Tux - 06.08.2008, 16:31
RE: Free air oder kiste? - von VIP__;) - 06.08.2008, 23:27
RE: Free air oder kiste? - von Ralph - 06.08.2008, 16:35
RE: Free air oder kiste? - von Tux - 06.08.2008, 17:02
RE: Free air oder kiste? - von semu - 06.08.2008, 19:05
RE: Free air oder kiste? - von Ralph - 11.08.2008, 11:46
RE: Free air oder kiste? - von ahaspharos - 11.08.2008, 13:30
RE: Free air oder kiste? - von Ralph - 11.08.2008, 15:08
  [Info] Alpine SWR823D ohne Kiste, einfach als Free Air ;-) danartham 11 10.330 02.04.2015, 07:00
Letzter Beitrag: danartham
  Welcher Subwoofer für den Skisack in der Kiste ??? karakartal2121 41 57.527 31.05.2014, 13:25
  Neuer Gehäusebau für mein Free Air Subwoofer Hilfeee !!! karakartal2121 24 24.176 20.01.2010, 17:38
Letzter Beitrag: Vibesy
  Definition Free-air timshanno 16 15.314 02.01.2010, 17:46
Letzter Beitrag: timshanno
  2 Free Air Subs einbauen karakartal2121 42 42.731 30.12.2009, 17:12
  Doorboards für mehr sound in der Kiste ring_of_fire 82 97.382 19.08.2009, 09:15
Letzter Beitrag: ring_of_fire
  Was passiert mit Free Air Woofer wenn ich von hinten schließe? soundjunk 2 4.381 14.06.2008, 17:02
Letzter Beitrag: soundjunk
  bass kiste auf der rückbank audi80cabrio2.3 34 22.354 21.11.2006, 20:14
Letzter Beitrag: wiegald
