Schaltplan des mechanischen Verdeck gesucht
Vielleicht kann das mal jemand ordentlich ins englische übersetzen, mit meinem Schulenglisch wird das nix, dafür ist es zu technisch!
Dear Sergey,
Ralph wrote:
It seems like that the wire harnesses in the trunk lid are damaged. Did you check these harnesses? Therfore you do not require an electrical scheme. You just need to watch out for broken cables in the bending section of the harnesses. Does the trunk lock?
Sergey,
In many cases the wire harness is the root cause of trouble with the roof; no matter whether it is a manual or an automatic roof.
To verify the condition of the harnesses you need to cut open the outer insulation of the harness to get access to the 7 to 8 cables inside (The quantity of cables depends on built year and left or right hand side).
If any of the cables is damaged, you should replace the whole harness or perform a repair of the broken harness section according to the instructions in our FAQ.
If you require further support, do not hesitate to post a line.
Lord
Zwo-Achter mit Allem
Please give me the reference in FAQ. (link)
[Bild: image.php?u=3&type=sigpic&dateline=1429649131]
Fast Sergey schrieb:Please give me the reference in FAQ. (link)
Certainly, here you are: Wire Harness Repair
Sergey,
we would prefer, if you could endeavour to start your request with a greeting and close with a greeting, as well; anything less is uncivilised.
Regards,
Lord
Hallo!
Danke für die Verbannung.
Und wo der Schalter des Gepäckraumes sich befindet?
Greetings!
Thanks for the reference.
And where there is a switch of a luggage carrier?
Un
  [Elektrisch] kompetente Werkstatt im Großraum Stuttgart für el. Verdeck gesucht alba2808 14 19.109 16.11.2022, 10:55
  [Suche] manuelles Verdeck öffnet nicht mehr, suche Schaltplan VDS oder MD 150 inCorso 8 11.595 24.03.2022, 18:15
  HILFE gesucht: Verdeck liegt nach dem Öffnen einseitig auf dem Scheibenrahmen auf audi100S 3 8.003 04.08.2013, 21:37
Letzter Beitrag: streaky
  Neues Verdeck steht wohl an, Preise/Erfahrungen gesucht :) Caynor89 16 19.556 17.05.2013, 09:30
Letzter Beitrag: Caynor89
  Schaltplan man.Verdeck?? zenkerd 4 8.817 29.01.2013, 13:30
Letzter Beitrag: hamag
  E-Verdeck gegen Manuelles Verdeck tauschen HILFE GESUCHT cabrioVerdeckwechsler 18 24.702 20.11.2010, 19:04
  Verdeckklappe Schaltplan Maunel K 3 16.856 26.10.2010, 09:21
Letzter Beitrag: Ubumannn
  Schaltpläne gesucht man. Verdeck moritz 5 9.583 21.07.2010, 12:38
Letzter Beitrag: audicab23
  Neues Verdeck - Bezugsadressen und Verdecksattler im Großram Düsseldorf gesucht Tombow 13 25.245 17.04.2009, 19:26
Letzter Beitrag: hjhimm
  Gebrauchter Hydraulikzylinder E-Verdeck gesucht Spiderschwein 7 11.003 16.05.2008, 10:14
Letzter Beitrag: Gerti
