Öltemperatur- und Druckmessgeräte
Good morning everyone,
I have read the various posts on this topic and hope that someone with experience can explain a few points to me.
My oil temperature and oil pressure gauges are showing incorrect readings; the pressure always shows the maximum value, but the temperature never shows. From what I've read, this indicates a problem with the sensors or wiring. The battery voltage sensor shows the correct readings.
I purchased the correct oil temperature sensor and will install it. However, I'm hoping someone can confirm the part numbers for the oil pressure sensors for the 1.8ADH engine. I'm surprised that there seem to be different sensors!
Thank you all.
Chris
  Kühlmittel- und Öltemperatur Benz 12 14.173 28.07.2015, 12:49
  Öltemperatur Anzeige ohne Funktion Manurix 7 12.806 19.01.2015, 16:49
Letzter Beitrag: Manurix
  Öltemperatur NG beetlejuicebln 14 24.115 23.05.2014, 20:50
  [Problem] Öltemperatur Steigt sehr hoch bei Vollgas Dikell2604 10 19.943 27.02.2014, 15:31
Letzter Beitrag: Dikell2604
  Öltemperatur beim NG bis 170°C Surs15 7 13.699 14.02.2012, 14:39
Letzter Beitrag: Surs15
  Motortemperatur seltsam, aber Öltemperatur OK ManuCab 7 16.269 07.09.2011, 09:01
  Niedrige Kühler- und Öltemperatur!? Wiesel10 34 75.282 05.05.2011, 22:33
Letzter Beitrag: StefanR.
  Öltemperatur - wann wird es kritisch semu 16 44.894 01.06.2009, 20:11
Letzter Beitrag: semu
  Wasser-und Öltemperatur Bobbycar123 21 35.402 26.09.2008, 23:25
Letzter Beitrag: Maveric
  Öltemperatur MrWhy 2 7.226 31.07.2008, 12:27
Letzter Beitrag: Sechserpack
