Probleme E-Verdeck mit VIDEO!
#91
N E W S U P D A T E.
I have replace almost every part, all cylinders, hydraulic pump, cords, locks, everything except the ECU and the parts in front near the grip. The fact is that it has been getting even worse during the exchange. the roof lid is the very problem, it won't open, the pump is just schrecking and the boom, dead. I have errorcodes in VAG-COm that the right upper hydrualic cylinder is bad, N83 on the pump is bad...
I found a Steuergerät in Hamburg, two weeks ago and today I installed it as a very last hope to get this D!€0eOw%n cabrio to work.
I installed the ECU and started up VAG-COM to reset it, and do you know what?
E V E R Y T H I N G I S W O R K I N G
A L L E S F U N K T I ON I E R E N 100%
The cab season is almost over here in Sweden but my daughter is sitting outside and opening, closing, opening and closing the roof.
So to look back. The cords in the back lid was broken, the oil in th pump was gone. I fixed that and had a lot of other errors that you all read about in this thread. But when I changed the ECU that so many said never break. Every single errorcode in VAG-COM disappeared.
So if you have a problem simular to mine. Do yourself a favour and check the cords and then change the Steuergerät, prompt. You will save hundreds of hours of checking for errorcodes and save a lot of money as well.
Thanks everyone that tried to help me out on this matter. NOW it's time to change the "blau Verdeck" I bought in April.
THE M I S S I O N I S O V E R.
LaolaLaolaLaola
CONGRATULATION !!!
semu
[Bild: 132139.png]
[Bild: sign2.jpg]
(12.09.2009, 18:38)Stout001 schrieb: E V E R Y T H I N G I S W O R K I N G
Hello Lars,
that's very nice to read. I suppose everyone appreciated/s that you didn't give up despite obscure errors and translation issues and so forth.
(12.09.2009, 18:38)Stout001 schrieb: NOW it's time to change the "blau Verdeck" I bought in April.
Good luck. Zwinker I'm sure you'll get it done in no time. Cool
Micha
[Bild: TJ.jpg]
Ich weiß nicht wie es Euch geht Jungs,
aber ich würd gern die Augen von Lars´Tochter sehen als er ihr das Cabrio geschenkt hat.
Wie ist die Story ausgegangen?
Bei -42° Grad im Moment bei Euch verzichte ich gerne auf Cabriobilder und gebe mich mit deiner Tochter zufrieden. Smile
(21.02.2009, 21:40)Stout001 schrieb: And... my daughter does not know anything about this and the car Big Grin She will get it as a birthday present when she becomes eighteen this summer.
Stimmt - die Tochter sollte das Cabrio seit Sommer fahren Big Grin
semu
[Bild: 132139.png]
[Bild: sign2.jpg]
OT:
Na Jungs, kommt der Frühling dieses Jahr schon soooo früh bei Euch durch??? Ich lach mich wech Na,na,na... Schlingel!
Luftige Gruesse
Oliver
BILDER
(veraltet, aktuell mit Cognac-Leder)
Zitat Assi: "Nur gucken -nich anfassen!" ;-)
  Diverse Probleme mit E-Verdeck Paulneu 10 7.894 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 3.020 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 7.811 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 13.962 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 4.921 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 9.570 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 3.557 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 57.359 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 16.490 03.06.2010, 18:48
Letzter Beitrag: Mauki27
  Manuelles Verdeck macht Probleme shaft cabrio 16 14.601 04.02.2009, 01:43
Letzter Beitrag: shaft cabrio
