Probleme E-Verdeck mit VIDEO!
#75
Hi Micha,
First did you get my e-mail reply yesterday?
(09.03.2009, 21:16)Jenkins schrieb: Hello Lars!
There's one controller, as Tux wrote most commonly sitting on sockets 5+6. This controller can have printed on it 367 OR 363 OR 343 OR sth. else. But always only one controller. Bigger than the others.
But there's one point where I disagree with Tux: My cab from model year 1996 obviously doesn't have relay sockets 19 to 22. 'Cause I couldn't find them. But of course I don't know the details for model year 1994. Or 1993. Zwinker
May be you should check whether there are relays under the rear seating or not.
Yes I have two relays under the rear seat but I don't know the numbers of them in my head. I will check ASAP (which means after writning this post) I will also check for the big controller.
I went out and installed the gas struts in the roof lid. Now the lid stays up and don't fall down anymore. I hooked up VAG COM and did a diagnosis and the first thing I got that I never got before was
01108 Power closing relay
28-10 J292
Short to plus
which in the documentaion I refer to :
[Bild: 01108%20-%20Relay%20for%20raising%20Windows%20-J292.jpg]
The only problem now is that I don't know where the J292 can be found.
I will contiune to view you the result of the check of the hood as I have some interesting results in VAG-COM, but that will be after the power windows have a solution. Zwinker
Probleme E-Verdeck mit VIDEO! - von Stout001 - 19.02.2009, 13:45
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 14:46
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 15:31
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 16:32
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 17:28
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 19:19
RE: Probleme E-Verdeck mit VIDEO! - von denis76 - 19.02.2009, 21:40
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 19.02.2009, 21:52
RE: Probleme E-Verdeck mit VIDEO! - von lemmy - 19.02.2009, 22:00
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 19.02.2009, 22:15
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:18
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 19.02.2009, 22:53
RE: Probleme E-Verdeck mit VIDEO! - von semu - 20.02.2009, 10:17
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 04:55
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 18:20
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 21.02.2009, 15:15
RE: Probleme E-Verdeck mit VIDEO! - von semu - 21.02.2009, 16:02
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 20:19
RE: Probleme E-Verdeck mit VIDEO! - von semu - 11.01.2010, 19:31
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 21.02.2009, 22:42
RE: Probleme E-Verdeck mit VIDEO! - von wiegald - 22.02.2009, 00:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 01:18
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 22.02.2009, 01:19
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.02.2009, 10:50
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 22.02.2009, 11:35
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 24.02.2009, 22:27
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 10:22
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 25.02.2009, 12:06
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 01.03.2009, 01:57
RE: Probleme E-Verdeck mit VIDEO! - von PeterH - 03.03.2009, 00:54
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 03.03.2009, 10:27
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 11:55
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 21:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 03.03.2009, 12:46
RE: Probleme E-Verdeck mit VIDEO! - von Grappa - 06.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 06.03.2009, 19:56
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 06.03.2009, 19:54
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 09:14
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 11:37
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 07.03.2009, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 13:16
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 21:16
RE: Probleme E-Verdeck mit VIDEO! - von Stout001 - 09.03.2009, 23:22
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 18:32
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:22
RE: Probleme E-Verdeck mit VIDEO! - von Tux - 09.03.2009, 19:35
RE: Probleme E-Verdeck mit VIDEO! - von Shamus - 09.03.2009, 19:48
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 09.03.2009, 23:59
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 18.03.2009, 23:05
RE: Probleme E-Verdeck mit VIDEO! - von semu - 13.04.2009, 19:23
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 22.07.2009, 14:42
RE: Probleme E-Verdeck mit VIDEO! - von Jenkins - 17.09.2009, 23:25
RE: Probleme E-Verdeck mit VIDEO! - von semu - 12.09.2009, 19:33
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 11.01.2010, 16:07
RE: Probleme E-Verdeck mit VIDEO! - von Owe - 12.01.2010, 13:31
  [Elektrisch] Verdeck Probleme JensGL 1 2.957 07.10.2025, 11:02
  Diverse Probleme mit E-Verdeck Paulneu 10 12.102 08.04.2021, 18:09
  Probleme Verdeck und Elektrik-neu Cabrio Selbstfahrer 2 4.753 03.07.2017, 12:09
Question [Problem] weitere Probleme mit dem Verdeck rosaflitzer 10 11.780 07.08.2016, 12:08
  Verdeck Probleme Nochber 14 20.210 15.02.2016, 22:08
Letzter Beitrag: Audimattes
  [Manuell] Probleme mit dem verdeck und mehr Doffl 2 6.523 21.10.2014, 19:08
Letzter Beitrag: Doffl
  Immer noch Verdeck Probleme Audi Cab 7 12.877 15.03.2011, 08:39
  Probleme mit der Verdeck-Kontrolleuchte Franz-Otto 0 4.616 11.10.2010, 17:41
Letzter Beitrag: Franz-Otto
  Manuelles Verdeck macht Probleme Volker 70 60 79.113 06.08.2010, 07:51
  Verdeck und ZV Probleme Mauki27 15 22.974 03.06.2010, 18:48
Letzter Beitrag: Mauki27
