13.04.2009, 19:23
(12.04.2009, 21:43)Stout001 schrieb: These are the latest VAG-COM codes:
01105 - Solenoid Valve 8 (N186)
28-10 - Short to B+ - Intermittent
00271 - See Repair Group 01
35-10 - - - Intermittent
Hi Lars,
according to my book "Reparaturleitfaden Karosserie Eigendiagnose" 01105 is the effect for the non opening of the lid. The cause could be 1) short to +, 2) magnetic valve 8 (N186) out of tolerance or 3) control unit J256 defect.
00271 is the effect for the non opening the convertible soft top and cause could be 1) operating error or 2) invalid position of roof opening button. The elimination of 00271 you already tried out with the described actions in the thread, but try to following this order: read out of failure recorder, bring soft top into end position manually, delete failure recorder, switch ignition off and on, push roof opening button, try a complette opening/closing
semu
![[Bild: sign2.jpg]](http://powersemu.de/car/cab/sign2.jpg)
![[Bild: 132139.png]](http://images.spritmonitor.de/132139.png)
