Noise when starting 2000 2.6 auto.
Hello,
New member from England here!
I have an automatic convertible from the year 2000, its a 2.6 auto and although it is wonderful in many ways, I have a problem that I find it difficult to find an answer to. Maybe you could help?
When I turn the key, the car makes a clacking sound and it sounds like it's struggling to start. It does however start and run flawlessly.
It does not start this way each time, sometimes twice in a row then it starts normally, which is most frustrating.
This noise at the start is annoying and makes me think I have a big problem in my engine.
I have a video attached so you can hear it.
I hope you can help me find the answer.
Many thanks,
Scott
https://vimeo.com/298898467?ref=em-share
Hello Scott,
you need a new starter, engine seems to be OK.
Normand
Hi Normand,
Thanks for your reply.
I had a new starter fitted last year as I thought this was the fault. I have only done 50 miles since then.
Unless the starter is faulty?
Thanks,
Scott.
Hi guys,
Can anyone else advise please?
Like I said I have already replaced the starter motor.
Thanks
Hi Scott!
Maybe even the new starter is not placed in the correct position. So that the starter pinion does not fit perfectly into the space of the other pinion. Because as long as that terrible sound is there even the rev meter doesn't show any sign of movement at all.
Maybe you should loosen (but not remove) the starter and move it a little bit away from the engine.
Hey Audiolet,
Thanks for your thoughts! I will ask my mechanic to try this.
Hello Scott,
when starting almost breaks the power supply together, how old is the battery? Maybe not renew? You should also check the earth cable on the battery and the body. Clean the connections.
Greetings Pierre
Hi Pierre,
The battery, starter motor and alternator were all replaced last year. But I will try to clean the cables. Thanks
  [Schaltung] Rückwärtsgangsperre entfallen beim Bj.2000??? ADR2000 13 14.856 04.05.2022, 19:46
Letzter Beitrag: Hias7
  Auto springt nicht an GerhardCabrio 10 14.241 26.03.2021, 17:46
  Motor Ausbauen V6, Jg 2000 747winglet 13 14.158 12.08.2019, 19:06
Letzter Beitrag: blue-elise
Exclamation ABC ruckelt im Teillastbereich bei ca. 2000 1/min - Warum? Grappa 8 20.762 10.11.2015, 22:44
Letzter Beitrag: Porsche-Doc
  Problem mit dem Auspuff beim 1.8 Bj. 2000 AbrigoRojo 3 9.486 15.09.2013, 21:40
Letzter Beitrag: AbrigoRojo
  [ABK] Öldruck-Lampe ab 2000 rpm chris_u 10 16.347 02.04.2013, 12:54
Letzter Beitrag: monskie
  Auto springt nicht an wenn es warm ist Devil311 10 26.333 07.04.2011, 11:29
Exclamation Auto gibt von alleine Gas *Hilfe* TimPeak 14 28.356 02.01.2011, 23:03
Letzter Beitrag: weichheimer
  Auto ruckelt - Lambdasonde? xcelent 8 19.982 17.10.2010, 20:27
Letzter Beitrag: xcelent
  Ruckeln zwischen 1000 u. 2000 Umdrehungen durch Gasanlage verschlimmert. TimPeak 4 12.944 28.03.2010, 18:25
Letzter Beitrag: Ollfried
